Hi. Does anyone no how i stop my tv from scanning channels on its own. Thank you
May you be more clear on what is happening and which tv do you have?
If i am watching channel 3 or any channel the tv jumps through all the channel numbers then stops randomly. Thank you
It’s a 65inch Sony Bravia Android tv
The only number i can think it is would be KD-65X8509C that’s the model number
I can be sitting watching a movie on Film4 then the tv just randomly jumps through all the television stations and stops at channel 701 for instance then iv got to turn the tv back to the channel i was watching
Yes iv done both i even purchased a new remote it’s definitely not that + it’s been rebooted afew times the tv is only 3/4yrs but i think at over 3grand it should last longer than that.
