basically i was trying to get the eurosport app up and running now its back and it states it needs wifi to find my location so after an hour of trying i cant get the wifi to turn on and do anything.
go through the settings to wifi turn on, check back a min later its off. try and setup the network on wifi get a message i need to unplug the wired network connection, so i do so now it still wont setup on wifi.
im honestly at a loss as to why it wont do it, wifi works on everything else in the same room of the house so the signals there, so im guessing either the tv's wifi is broken or yet again sonys android updates have buggered the settings up any ideas ?
Hi
Doesn't sound like a Wifi issue, so it's probably best to contact support for advice here.
Cheers,
Sean Mc
