6.1288 How do you turn off channel preview after pressing the TV button?
I have sky as my primary source, so HDMI 1 is assigned as TV input.
But I also have a terrestrial aerial plugged in
When I push TV it sets to hdmi, but with the list of Freeview channels displayed. If I try to select one, the remote fires the terrestrial number at the sky box .. which isn't useful.
Not the end of the world I know. But if there's a way of turning it off it would be good
Did you sort this?
I just received the new BT TV Box Pro and had a similar issue.
During the BT setup I skipped a step (I think it was channel setup) and now when I press TV it will turn on the box and only shows the pop up TV menu with Power, Home (menu) Options etc but no channel previews are shown.
Hey guys, are you using the Sony remote for the selection?
