I have interruptions during playback of TV recordings. I tried 2 USB 3.0 HDDs and one USB 3.0 256GB stick. Issue occurs on all 3 storages. Before i used same HDDs on a XD80 and XE85 without any problems.
The interruptions are not in the recordings because when i seek back some seconds and play again, the playback is OK.
Here is a sample:
Till now the issue occurs only on SD content, but i have to 90% only SD recordings. PayTV is not used.
Sony 65XF9005 - Sony STR-DN1070 - Apple TV 4K [Früher: Sony KD-55XD8005 - Sony KD-55XE8505 - Sony KD-55XF9005 - Samsung 55NU8009]
Hi mpiet1,
Have you tried performing a reset or a Factory Data Reset on your KD-55XF9005? If not, please try this and let us know how you get on.
Cheers,
Pascale
Yes, i performed several factory resets before, did not help. Now i performed the update with factory reset and i did not notice the issue, but i watched only 30min recordings.
I will observe it and give feedback.
The interruption issue still occur, but not on all tv stations and not on all tv content.
Issue 100% occurs watching to RTL SD (Astra SAT 19.2E) "Alles was zählt" and GZSZ (Monday - Friday 19:05 - 20:15).
Watching to other RTL SD content issue do not occur. So it seems to be depending on transmission details like framerate, biterate, etc...
