Hello,
I have just purchased the above TV. I have my Sky+HD box connected to it (purchased Sky in May last year 2016).
In simple layman's terms (so I can understand - I have googled but still not 100% clear), please can someone tell me whether I can change input setting i.e. HDMI1 to 'Enhanced HDMI' or should it be 'Standard' setting ?
Many thanks
Hi there
The most simplistic answer is that the HDMI settings should be left as 'Standard' unless using HDR. The Sky+HD box you have is not HDR, so leave this setting and Standard.
Thank you Quinnicus.
