I'm having trouble registering my 55" OLED a1. When trying to select the TV (either via the model number, or the 'Search by Category' metgod) only the 65" model is listed. The model number is (KD)55a1bu.
Anyone know wht the valid option is, if it exisits.
Hi @Monty72 and welcome to the Community
If you type KD-55 into the product details box on the registration page
you can then select the KD-55A1 television.
