HI PLEASE COULD HELP. I HAVE FORGOTTEN MY 5 DIGIT PIN CODE FOR THE TV. WHERE DO I FIND IT OR CHANGE IT?
Good Morning
The following instructions should allow you to reset your pin number. You will need to reset it via the SEN website
https://us.en.kb.sony.com/app/answers/detail/a_id/61670/
Hi there
Can you please tell me which 5 digit code you are referring to? Is it the Parental Lock - if so, thats a 4 digit password.
Morning Quinnics
Thank you for your reply.
At the top left corner it's says Video Unlimited Enter PIN
underneath Please enter the PIN for my email address.
Then PIN the 5 boxes.
kind regards. Liz
Good Morning
