The TV will not turn on, it has a red light flashing in groups of 8 does anyone have a suggestion of what to do ?
Tried the help line but it was closed with out giving times of opening.
Hi @dadrocks2 and welcome to the Community
Which model TV do you have?
Have you tried a power reset or a factory reset on it?
This may help, but I believe the 8 flashes relates to an issue
with the main board of the TV so you will probably have to call
Support on Monday on +44 (0) 2073652810
Is your TV still in warranty?
Thank you for replying its a KD - 49X8005C
We've had is 23 months.
We'll call sony on Monday
I'm currently experiencing the same issue - did you manage to get yours fixed, and if so what was the solution so I can apply same to mine please?
this chart applies to 2015 models and it states it no hardware error and my involve main board or wifi module.
Thanks for this chart, it looks like a wifi or main board issue, hopefully can be repaired once the servicing company re-opens.
Step 4 in the chart talks about isolating the board, but I don't have any instructions on how to do this.
