Hello, i have this model for a month and I noticed that, when you cleaning the sreen with wipe or something, the panel is moving for around 2mm from frame. Is it normal or I have go to replace this? I was on the shop where I bought it, and I touched the sreen of bigger size model (49xf8096), and it also moved, but not that much as mine.
Ok then, I went into another shop, and touched exactly same model with same size, and it moved like mine. So I think it's normal..... But i must notice that build quality in this brand gets lower
Hi aivaras123-,
Welcome to the community.
It sounds like it's normal then.
Thanks,
Pascale
Maybe there is some other users of this KD43XF8096? If yes, maybe you can check if your panel behave like mine? I'm very interested in this
thanks
