I notice that when I set a timer within the program guide for TV channels, then a "red bar" appears along the timeline, but there is no indication in the actual program entry itself. No dot in the program box.
This is a real pain... if you want to come back later and set another program, then you are unsure which program is causing the "red bar" - so you then have to go to the timer list to find out (and go back again etc).
Why not put a red dot in the program box entries? Then just by bringing up the guide, you could see which programs have already been set for record?
Hi TBill01,
Thanks for your suggestions for this program guide and timer, we welcome your feedback.
Best wishes,
EdwinaU
