Hi
New Member with a problem...
I have 43XD8305 connecting to a MT500 soundbar....a few days ago the soundbar stopped starting when i switched the TV on. The Soundbar works as i can switch it on seperately but my SkyQ box has no sound. The only way to get everything working is to switch everything off at the mains, then everything works.
I've tried Sony support who had me changing leads but nothing's worked. Has anyone got any ideas?
Regards
Paul
My apologies its Playback_2.........no idea where the TV is getting that from....the TV has also had a factory reset
This is where i left it last night....The TV has also had a full factory reset
Ok this could be ok since my soundbar has not any playback capability while your I think could play music files via USB.
It's strange that even if you reset the TV and SkyQ is not connected you still see it on the list. What's happen if you push enable? it should send the HDMICEC enabling command to the soudbar and you should see something line "Complete" on the soundbar display.
Do you see afterwards the soundbar setting in the setup->sound-> Home theatre control? You should be able to command completely your MT500 via the TV...
Hi
Yes i see an enable button and when i press it it gives a message to say its sent a message to the device but then nothing happens. I can control the soundbar with the TV remote.
Funny though that the Home Theatre screen doesnt always allow me to change the settings....sometimes it just shows me a compatibility window.....almost as if its NOT compatible.
I read somewhere that there's a was a way of emptying the TV's cache?
Paul
You cannot empty the whole cache, you can do it app by app... Are you sure about your HDMI cable? Have you already tried with another one?
Hi
Its a brand new Blue Rigger HDMI cable. I've tried 3 different ones now.
You any idea where the Player_2/Playback_2 is coming from?
I've registered with Sony now too
As I said it should be related to the fact that your HT (unlike my old HTCT350) is able also to play music. But this should not be a problem.
Is there any way i can reset everything so it only sees the Soundbar like for the first time?
Is it a TV problem or a Soundbar problem?
P
You should be able to do it, disconnecting everything (when not powered on), redo the display braviasync device list and enable... you shoudl see nothing. than reconnect the soundbar (always powered off both tv and bar) and redo it.
But now it is working or not?
