All in all there is 3 major problems.
Problems with blacks and contrast in expert temperature mode that is present in any picture mode: when you activate this temperature mode contrast and blacks (with or without activated blackadjust or adv. contrast enhancer)not exists.
Motion problem: motion is much better than before marsmallow but not as it should be:motion is without fluidity specialy in true cinema
Hi there
The colour temperature bug is a long ongoing issue that still remains unsolved. see:
https://community.sony.co.uk/t5/android-tv/2015-android-tv-bugs-and-issues/m-p/2175704#M83
In regards to Motionflow - I am not sure on what you are referring too. Can you explain further?
Well, ok.
Until april 2016 truecinema (my favorit)was normal, smooth, fluid, cinematic .After april 2016 "truecinema" and "of" became same:very rough , tiring, maybe too slow, somehow without any processing action.Modes smooth standard and clear have opera soap efect but that is normal, ok.They are not problem.
