I'm trying to watch a 3d movie which is on a USB drive, when I plug and play this using a external device and try to change the display settings to 3d display on with either side by side or over under, even though the movie plays in the background as 3d, half the screen is covered with the 3d display options is there any way have the movie full screen?
Hi there
Once you set the 3D setting to either SBS or OU upon pkayback of 3D content, you can cancel out of the 3D options menu.
