x
3D in Action Menu - Android 6 (BUG N8)
SOLVED
profile.country.UA.title
svansvan
Contributor
https://community.sony.ua/t5/android-tv/android-tv-bugs-and-issues/td-p/2040020
(BUG N8) No 3D Options in Action Menu
https://community.sony.ua/t5/android-tv/android-tv-bugs-and-issues/m-p/2089584#M69
!!! Please remove this item !!!
In Android 6, it is not only not fixed, but also the opportunity to use a single solution:
Work-Around:
Use the Video and TV SideView app on a smartphone or tablet.  Alternatively, if you have a previous generation remote control, this has a dedicated 3D button which works.
This is a targeted destruction of this option!
You mislead people. People hope to fix this problem. But this is not a problem for Sony!
And it does not does not look like on another bug. Rather, this is a mockery.
People need to know what they will lose with the update to new firmware Android 6.
And just do not have to point out the problems in third-party players again.
It's just a window setup. Which now nowhere and nowhere to call, except for the standard player.
KD-55x9305c + SPS4 1208b
10 REPLIES 10
profile.country.US.title
LoganT
Explorer
Sadly, I apparently didn't have Android 6.0 and after I upgraded my trick doesn't work anymore.
