I just bought a Bravia xd93, for some reason I cannot watch 3d with my glasses further than about 3ft from screen. They lose signal and go off, i tried my glasses on another tv and they work fine.
Hi there
Hard to know why the range is so short. Some suggestions:
Tried all these thanks, this is what tech support offered.
they going to call me in 2 days so they got time to investigate the issue.
Hi there
Let us know how you get on with a resolution - it might just help someone else if they have the same problem too.
Sony tech support has been very poor, only advice after several contacts so far is turn tv off and factory reset. I can't be only one with this problem? I just want to take my tv and bluray and glasses back forvrefund 😔
Hi there
A couple of reasons why Sony suggest a factory reset
Advise you to stick with Support - But if you get stuck at any point, post back and ill see what we can do to help progress further.
