Has been awesome all tv os should be android not hade a single problem with it if I want a app and it's not on the ported to store I just install the apk and side load it only thing I will say is that should at least give users root permission so that some mod stuff will run on it it's some times a pain in the back end when a app loads side ways but Uther than that I couldn't go back to a web os or any Uther os that's so tied down and dose not have support off a moding county
Excellent. Glad you like the TV, its good to hear a positive story.
Thank you
What model is it as I'am beggining to wonder if all these complaints in the past and present are due to hardware issues on a particular batch or model, if yours works okay then why dont others?
How much have Sony paid you too?
a Sony KD 43X8309c and I am on the December the 10th update as well and not one problem so far
