Hi
i am hoping someone can help with a solution
i purchased a 2020 model Sony Bravia KD-49XH8196 thinking because it was Bluetooth it would support my Jabra Sport ear phones. Unfortunately I have since found out it doesn't
is there anyway round this that would allow me to "make" the TV support them
i specifically looked for a to with Bluetooth so that I couldn't listen via Bluetooth earphones
any help much appreciated
best
On newer tv models you may look in the community for app that can add up the a2dp profile and workaround the problem
Download an app called Bluetooth Scanner from the Google play store ,you will by scanning with this, find that you can add on your headphones .
This workaround worked for me
