I thought I'd create a generic thread to cover off the issues being encountered on the 2015 Bravia Android TVs. I've listed my issues below with fixes / workarounds and responses from support. All comments and solutions welcome!
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
2) HDD Recording doesn't work - error message states a system update is required but none is available when checking. Hopefully this will be fixed soon by a firmware update.
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
4) Sound lag and performance issues after the TV (KD-49X8305C) has been on standby for a while - manifested for me as stuttering and sound / picture sync issues in all apps (youtube, amazon instant video etc) and HDMI sources (PS4, seperate YouView box etc). Hopefully this will be fixed in a firmware update, at the moment workarounds involve either changing channels to get the sync to work or in my case having to turn the TV off and then on again at the socket.
As stated previously, all comments welcome. Personally I'm willing to give Sony a couple of weeks to fix this, but if it's not done soon I'll be sending my new TV back for a refund as it's not really fit for purpose.
OK, update done. Still testing,
To make life easier, can we just start a faults list, Maybe carry on the template below ?
Pre update faults
1. Sound when turning tv on, with a sony sound bar connected. results no sound from sound bar or the TV.
work around, (Using remote switch from HDMI1 to HDMI/ARC then back to HDMI 1 and sound will work properly.)
Faults found since update
Which model is the soundbar? How have you got it connected? It should be connected ARC (HDMI x ARC).
After any update or factory reset the touchpad remote will need to be paired again with the TV.
Are the touch remotes a lot better than using the Android TV app?
CT370 connected to HDMI/ARC and Cable box to HDMI 1.
Re Abercrombie post its -vol and the power button and the touchpad for 5 seconds. While your TV is unplugged from the mains first. Then Power on after u see the flashing lights on the inside of the remote back cover on the underside..then factory reset your TV..which we are all familiar with
Just had to do that one!
