- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
2015 Bravia Android TV Issues
I thought I'd create a generic thread to cover off the issues being encountered on the 2015 Bravia Android TVs. I've listed my issues below with fixes / workarounds and responses from support. All comments and solutions welcome!
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
2) HDD Recording doesn't work - error message states a system update is required but none is available when checking. Hopefully this will be fixed soon by a firmware update.
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
4) Sound lag and performance issues after the TV (KD-49X8305C) has been on standby for a while - manifested for me as stuttering and sound / picture sync issues in all apps (youtube, amazon instant video etc) and HDMI sources (PS4, seperate YouView box etc). Hopefully this will be fixed in a firmware update, at the moment workarounds involve either changing channels to get the sync to work or in my case having to turn the TV off and then on again at the socket.
As stated previously, all comments welcome. Personally I'm willing to give Sony a couple of weeks to fix this, but if it's not done soon I'll be sending my new TV back for a refund as it's not really fit for purpose.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I sent my Android TV back a few weeks ago and exchanged if for LG. Glad I did. Sony know about all these issues and have had numerous (I would guess 100's) complaints.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@danielbeyzade I have sent you a PM..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@fether And others, you can disable Youview in channel settings. The Tv then uses the old guide.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just an update. I have had a few users send their complaint regarding YouView satellite and HD recording not working in combination using my template. Please can anyone else wanting to join this PM me so I can give my email to CC. The more users we have demanding an official response the better our chances.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm not sure if it's me being thick, but the YouView guide that I have has only about 6 channels? I've got bbc 1 and 2 hd, ITV hd, cbbc hd and channel 4hd, no channel 5. Also a couple of red button channels. That's it, a the other freeview channels seem to be missing.
I'm at work now so will have another pop tomorrow, but has anyone else seen this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you disable youview do you still have access to itv player,all4 and demand 5 and satellite function restored.This is the setup I would prefer but I,m not a technical and dread having to try and get everything back as it was if I attempt to disable youview.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try it mate. I think once it's been set up and enabled it's just a matter of on or off in the digital channels menu.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I only use a satellite connection as tv aerial signal is not good here. I can use YouView, it just doesn't show the live TV.
What I am totally miffed about is that I've lost all my satellite channels and the option to perform a "Satellite Set-up" is now greyed out?! Have they REMOVED this function?
I'll be taking this TV back tomorrow if this is the case. Anyone else have this problem?
