many side-by-side 3d videos can be viewed with 3d mode, but some not. Especially the few promissing ones in UHD from Taeuber 3D do not seem to work (e.g https://www.google.fi/url?sa=t&rct=j&q=&esrc=s&source=video&cd=2&cad=rja&uact=8&ved=0CCIQtwIwAWoVChM... TV seems to try switch mode but remains showing side-by-side.
I ponder if it is cause of the material, app or the tv.
model 55X8509C
Thanks
Uhmm, 3D in 4K I don't think it's possible AFAIK....
I have 2015 Android 3D TV but dont have a blue ray/DVD player. Are there any apps available to view 3D movies (free/paid)?
Thanks.
Hi there
There are many 3d test files on the net. Google is your friend here. There are also loads on YouTube as well.
Some examples:
http://demo-uhd3d.com/categorie.php?cat=trailer3d
http://www.demo-world.eu/3d-demo-trailers-hd/
http://www.3dtv.at/movies/Index_en.aspx
Thanks Quinnicus
Are there any apps in Android TV (like Netflix, Playstation Video) to buy/rent 3D movies?
Unfortunately i dont actually know - in specific to 3D, i doubt it. I understand that there are many addons for Kodi - maybe one of those may do it. 3D movies is generally bolted onto other streaming services (ie netflix)
You can watch the SBS or OU Youtube videos that are not automatically recognized as 3D by clicking "Action menu" button on the remote, while in Youtube and enabling 3D. Same is for the preloaded Video app.
