Hi, desperately need help here as this is driving me nuts.
I cant get 120hz at 1080p on my 65xe9005.
I have conected my pc with amd 590 which more than capable trough hdmi to my tv.
I have tried every possible setting including the enchanced option on tv, even creating a new resolution ar 1920 1080 120hz but all i get is the tv wont do 120. This tv is 120hz capable and this is driving me crazy.
Please help
120hz capable?...
Manolo
Have you confused the Hz of the panel with those of the signal?
Manolo
Thats crazy! All the reviews I read tested the tv as 120hz capable, also there are many se9005 owners on forums that are using it at 1080 120hz, and I am sure I was told it was 120hz from the shop I bought it from just a month ago.
Its also listed as 120 capable here
https://www.displayspecifications.com/en/model/65f6a4b
Could it be a europe vs usa specs?
So is this tv not capable of 120hz? It supposed to be sonys premium model..
Hello @alexhill,
the TV has a refresh-rate of 120Hz (NTSC) or 100Hz (PAL), it just doesn't support 120Hz/100Hz signals.
It interpolates the frames in between when using e.g. a 60Hz or 50Hz signal.
Could you please link the reviews, which stated it would work with 120Hz/100Hz signals, since Sonys product page clearly states the highes refresh rate signal it supports is 60Hz.
- Nic
Manolo
Heres the first one that pops up Ill find the others too
Tested 1080p @ 120 Hz
And here is another
"The 65-inch TV boasts 4K resolution and HDR support, a panel with true 120Hz refresh rate "
https://www.tomsguide.com/us/sony-xbr-65x900e-4k-tv,review-4952.html
