Hi everyone, I have my brand new A7iii but I have some problem. I am a tv producer and I shoot using 1:66 format. When I select 1:66 guidelines they appear two vertical lines, but I need them to be horitzontal. Can I change that? Is there any option that can help me to frame at 1:66 aspect ratio?
Hi xvaldes,
can you elaborate more on what settings you have set for the grid and marker settings? Because as far as I can tell, these vertical lines are representative of the 1:66:1 aspect ratio selected.
Cheers,
Tenneen9000
