Will a Sigma lense fit?
SOLVED
profile.country.en_GB.title
elhewet
Visitor
Is there anybody out there that knows if I can attach a Sigma auto focus 70-300 Apro macro lense to my new Nex5? It says A-is this the mount? It fitted my Pentax MZ-30 in the days of 'film'. Is there a converter to fit and if so would it function well or do I need to buy yet 'another' zoom? Best place to buy would be great too...thanks Liz
1 ACCEPTED SOLUTION
Accepted Solutions
Mick2011
New
Hi Liz :slight_smile:
If it's an A-mount lens you can use the LA-EA1 adaptor:
http://www.sony.co.uk/product/dsl-lens-accessories/la-ea1
I can't be sure if it is an A mount lens without seeing it; I'd suggest taking it into a Sony store and asking there, before buying.
Mick
3 REPLIES 3
Mick2011
New
Mick
elhewet
Visitor
thanks Mick for being so quick. It says A before the string of  f numbers  right near the screw mount. but will locate a store if one near me and check the lense out and look at the site too. As it cost so much back in the nineties and has sat there in the cupboard while I used the 'latest' sony compacts I feel would like to trial it before launching into '3rd' zoom!!!!!!!!!!!!The other is a Takuma K mount used on the pentax ME Super and a bit heavier.
Thanks Liz
Mick2011
New
If you have an aperture ring it's one of the older autofocus Sigmas (later ones have no aperture ring) and the 'A' is most likely the setting you use for automatic aperture selection by the camera. Reading your original post again, the MZ-30 you used it on would have been a Pentax K or PK fitting, so the LA-EA1 won't be of any use to you.
There are adapters for Pentax K to Sony E-mount – this is what you need for the NEX5 and while some are better than others, you won't be able to use your autofocus.
Maybe you're ok with that and don't mind fiddling with a few settings to get it to work..? Quite a few die-hard Pentax users are happy to put up with a little inconvenience in order to use their beloved old lenses and the RainbowImaging adaptors seem to be the ones they're going for:
http://www.amazon.com/Pentax-PK-EM-mount-lens-adapter/dp/B0046BUWUM/ref=pd_sim_sbs_p_4
Good luck with it, whatever you decide :cool:
Mick
