Hi all,
I have a Sony A57, I currently building up my essential bits of kit and one thing I need is a wireless shutter remote I found a couple online can anyone say if they tired them at all or recommend any?
http://www.amazon.co.uk/iChoose-Wireless-Infrared-Replacement-IRMT-DSLR1/dp/B004XBK08Y
http://www.amazon.co.uk/Wireless-Infrared-Control-Milnolta-IRMT-DSLR1/dp/B002VM49KC/ref=pd_cp_ce_0
Im also looking at a 35mm fixed lens (below) any thoughts on it as i want it for travelling so im not carrying alot plus to try Bokeh Art.
http://www.sony.co.uk/product/dal-portrait/sal-35f18
Also can anyone recommended anything else I need below is currently what i have
kit lens 18-55mm
sony zoom lens 70-300mm
UV/Polarised filters
cleaning kit
tripod
Message was edited by: cooke69
The RMT-DSLR1 is fully compatible.
However with the new RMT-DSLR2 you can also start/stop the movie recording, whichis not possible with the version 1.
The SAL35mmF1.8 is very good and a perfectmatch for the A57. You can read a lot of reviews on the following site:
http://www.dyxum.com/lenses/Sony-DT-35-F1.8-SAM_lens588.html
Best Regards
Michael
Hi cmosse
thanks for the reply, the RMT-DSLR2 really does tick the box but the price seems a bit steap, do you know of any cheaper ones? have you heard about the two i posted above?
Also i'm def looking at the SAL35mmF1.8 the link you posted was great, is there any similar lens with F1.8 about 35mm or below for a good price I've been looking and cant see.
One last thing does the Minolta lens just fint on any Alpha DSLR? and does it only allow manual or auto focus?
cheers
