Hi
I have just bought a 6400 with the kit lens 16-55. My question is: Can anyone out there advise if I can use the Cokin Size S (previously A) adaptor with 67mm x 67 mm filters on this camera. I have filled an adaptor to take the filter from 40.5 mm to 49 mm and have fitted the Cokin S size adaptor but before I buy filters I would appreciate any advice.
Many thanks
Alan
S size has 67mm filter size
If you have the SEL1655G (67mm filter size) you don’t need for any adapter.
If you have the SELP1650 (40,5mm filter size) you need for a 40,5 to 67mm adapter (in one or more step)
Hi and thank you very much for that - a very clear explanation - much appreciated - btw love the a6400 - but its a big learning curve - thanks again - Alan
