Hi! I want to update firmware on my NEX-5. I've got version 03, and when I read about the 04 version, it says on Sonys homepage, that only cameras with version 04 i supported. I cant find the version 04 anywhere.
Or can I go from 03 directly to 05 anyway, dispite what's written on Sony's homepage?
Anyone knows what to do? BR / Björn
Saw now that it says support for ver.04 OR LOWER!!!
Case closed!
BR / Björn
Message was edited by: bjogra
Hi Bjorn.
You can update the firmware direct from Version 3 to Version 5.
Follow the instructions carefully: -
http://www.sony.co.uk/support/en/product/NEX-5/downloads/FW_NEX5_V05_WIN
Hi Bjorn.
