I have checked the compatibility charts but cannot seem to find a match, yet I see postings with people referencing teleconverters that they use. Can anyone help me with a suitable teleconverter for my setup please. Thank you.
Yea I would look into the above links, but if you mean something else, or talking about another model you can type it down and we'll try to check it, cheers.
Thanks for the response, as I said in my post, I have already checked the compatibility chart to no avail.
Thanks. The two Sony lens mentioned only work with, I think 3, G master lens and so no good for me. I have seen reference to using a converter with an Alpha 7 camera and non-G master lens, I think it was on the Facebook Alpha users site, but cannot find the entry now. Is there anyone on here using a teleconverter with a non-G master lens?
