Where it is gone? No product support anymore?
Ok Thanks. Seems that my local site doesn't have those links.
https://www.sony.fi/electronics/support/e-mount-body-ilce-7-series/ilce-7rm3a/downloads
In that case, you should probably reach out to your local support before trying to install the update.
I believe the link I shared is for models sold inside Europe, but I could be mistaken.
Hope this helps!
- JD
