Recently upgraded my Godox V860ii for the version iii, and I just noticed the in-camera AF assist light no longer works. I realise the newer flash had a built-in modeller light, but it is a lot more obnoxious (continuously on) compared to a quick flash of the camera lamp. Has anyone else had this issue?
Thanks!
Hey @dhobiwankenobi, which software version is currently installed on your camera? The AF function can be only used when the camera’s software is v3.00 or later. Also, try to remove the Godox V860II and test the AF assist again.
