How to set flash bracketing on a77 with hvl-43am flash unit in aperture priority or manual mode
I dont know if you received my first reply but since then i have managed to overcome the problem I was hoping
that flash bracketing worked the same as exposure bracking with just one press of the shutter but apparently
you have to press the shutter for each exposure . thankyou for your info Regards welshman1920
Hello welshman1920 - Welcome to the Sony Forums
When available, the flash bracketing settings can be found by pressing the 'Drive' button and then selecting 'BRK:C' or 'BRK:S' to see the available options. There is some information in the manual about this that you can read from page 155 onwards:
http://pdf.crse.com/manuals/4291132131.pdf
Let me know how you get on with this
Simon
