I have an a7II with sony zeiss FE 2,8/35. Brand new 14 days ago. If i shoot in A, S or M, smaller than F8 and following focus mode, focus working forward and backwards like a cradle a few seconds before stabilizing. After a few shots you get unwell and dizzy. Are there some others out there who has expired the same?
From F9 to F22 it seems to work ok.
Robert
Hi Robert,
Depending on your motif and your viewing distance this could be normal.
If your subject hasn't much contrast or lighting conditions are difficult AF will need some time to focus correctly.
PD
