Just recently when I take photos using the A setting my photos come out in black and white? Any ideas what I am doing wrong?
The easy option is to reset your camera and see if all is set like you like it.
The better option is a search on the web for ' Sony uk manual a57' and study settings of your camera.
Which camera model have you got? and have you tried to reset it by removing the batteries for a few mins and insert them back ?
Thank you.
I'm sorted now after resetting. Many thanks.
All sorted now - camera reset. Thanks.
That sounds great! Just make sure to update the case as resolved on the campaign checker.
