I recently bought an A350 for my daughter and now need to a compact flash card. can anyone recommend one? Also can you use SD card with them. thank you
Hello shellen - Welcome to the Sony Forums
The A350 only accepts Compactflash cards so you will not be able to use an SD card with it. In general, these can be obtained from online retailers such as Amazon and I see that they have a 4GB version of the Sandisk Ultra card for around £10 - this should perform well in the A350 and if necessary, there is also an 8GB version for around £15.
Thanks,
Simon
Thanks,
Simon
