I have a problem with the uncompressed RAW images from my A1 when transferred to either my Samsung S21 Ultra or Tab 7+, the images appear as a non supported in the gallery app (a white box with an exclamation mark) but when added to Lightroom mobile they work correctly.
My previous A7RIII RAW files worked perfectly before I changed to the A1; it's annoying as I want to copy off images to clear the card while shooting but still be able to view them easily and delete if necessary without having having to import them all into Lightroom first.
Anyone have any ideas or suggestions?
Thanks,
Jon.
@jonwood10, that doesn't seem to be an issue with the camera, try testing it with another phone.
