Hi, im new to this, i have an Alpha Nex-5 Version 1 and want to update the firmware but dont know ifits safe to do so. i dont want to risk doing a damage to my camera, i need to know if its safe to go ahead...Thanks in advance.
Hi grannyscoobs,
welcome to Questions & Answers..:smileyhappy:
As long as you correctly follow the How to update ? instructions provided then you should be fine..
Here is a link for the firmware update for the Nex-5 (presuming that's the camera you have) - NEX-5 Firmware upgrade (Windows) - http://www.sony.co.uk/support/en/product/NEX-5/downloads/FW_NEX5_V05_WIN
Hi grannyscoobs,
