Hi..
I just got this lens to use it with my a6000, and to my surprihttps://1921681001.id/ se, the side button on the lens does basically nothing, and I can't find a way to set it up, anyone here with the same combination that can help me?
Thaaaaaanks https://19216811.cam/
Hey @zintapritie2,
Just to be clear, are you talking about the button or the toggle? cause there's 2 to the side of this camera.
Also, have you tried assigning any function to this button through the camera settings?
Cheers.
