Hello everyone
I have a Sony SLT-A77V and finally have Kenko extension tubes with autofocus
The autofocus doesn't work. Please see my video:
I tried it with manual focus too but it is still just a blur. What could be the reason?
Thank you,
DistantMelody
I have tried them with a Sigma lens and was only able to focus manually. AF doesn't work for me yet. Please see my the sample shots I took (photo 1 is a 2cm wide doll's hand with powder from being sanded, photo 2 is a cushion cover).
Hello Mark
Thank you.
But why doesn't the AF work? Is it a fault with the tubes or camera?
My own judgement doesn't seem to be good enough because the images are mostly blurry. When I have the apeture at f4.0 only a small area is in focus but the shutter speed is fast, which is good because any tiny movement shows up at this magnification. When the apeture is at f22 - f29 the area of focus is larger but the shutter speed is extremely slow, so the photos are blurry.
I found that the wheel normally used for zooming, with these tubes is for focus. And the focus wheel does very little.
I have a problem with this lens. Most of the close-ups I did were aimed at the ground. I had the camera on a tripod as usual. The lens wheel moves by itself, simply because of the weight of it. I set the focus, take a picture, and see that the lens has moved and gone out of focus. This may also be causing the images to be blurry. I tried holding the lens wheel to keep the focus as I set it but that creates trembling of its own. Have you had this problem? Is there an addition that can be joined to the lens to stop the wheel from changing?
Would it be helpful if I put some examples of the shots I took and 100% close-ups?
Hello Mark
Congratulations on the birth of your child!
I have registered on Dyxum. I have the same name there. You were right. The lens and the tubes have different joints.
Does it mean that with this lens there won't be autofocus? The tubes and camera have the same joints. I don't know if I can film macro videos without auto focus.
I have a sony remote control. I use it. I will try without the steadyshot next time.
I haven't bought any new software yet. I have also been away for some time and didn't have any camera equipment with me. But now that I am back I have been experimenting with this new toy.
It gives vast capabilities for filming/photographing in a small area.
The rubber band idea is a good idea. I will look. They need to be quite wide and strong?
she's keeping us very busyHello Mark
I was able to change the apeture when taking photos. I am using all 3 tubes for maximum magnification and coolness. In the video I had the original camera lens. Now I am using the Sigma because it seems to have a wider range of focusing distances (manual). I will test each tube as you say and see what happens. In the photo on the left is the camera with tubes attached and on the right is the Sigma lens.
