Hi connected my Photodiox adapter to the A6000, Nikon 50mm 1.8D works fine Nikon 28-300g Lens is terrible any help would be appreciated
What exactly is the problem? If 1 lens works fine, how is the other one terrible? Can you explain a bit more about the problem? I've had a photodiox adapter also that was way too tight on the mount.
