A panorama photo made with a SLT A55V is shown on the lcd-screen of the camera like a 'short movie' or a 'small band'. Down-loaded on the pc with PMB-software, only the 'small band' picture is rendered. Is it also possible that the 'short movie', full screen picture will be shown, and if so, how to do it?
Hello PeterOnbekend - welcome to the Sony Forums
This may be something that you have already done, but it may be worth checking that you have the latest version of Picture Motion Browser installed on your PC (I have seen another user with importing issues in the past and they found that the necessary features became 'active' with the latest version of PMB installed).
Full instructions for the download are available here (it appears that there was a recent update on 15th November 2011):
http://www.sony.co.uk/support/en/product/SLT-A55V/downloads/PMB
Hope this helps,
Simon
Dear Simon,
Thank you for your response!
The version of PMB as installed at my pc, is: 5.8.01.09211. As confirmed via the Help-function, it is the latest one. However, so far I am not able to reproduce my panorama photos in another way than the so called small band.
By the way, I also posted my question at the Dutch part of the Sony Community, still going strong in finding a solution for something which must be possible...
Regards,
Message was edited by: -Cass-
Hello again Peter
I will look into this further to see if I can get an answer for you - hopefully there will also be some input on the dutch version of your question.
Thanks,
Simon
