Hi Guys,
I have a problem with my NEX7. It turns on ok, but when I turn it off and then try to turn on again, nothing happens.
I have to take the battery out and then it turns on, but only once.
Can anyone help me?
Thanks
Does the same thing happen without SD card?
I would try a factory reset...
I can't think of anything else you can do...it's the beginning of the end?
