I bought my nex-5n in uk, but i wanna change it to Chinese.
I have already try to find out in the setup menu but I can't find the languange bar, what should I do now.
Help! Please!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hello janelqz
Just to add on to what Mick was saying, there are a number of languages provided in the menu but as the camera was purchased within the European market - if you cannot see Chinese it is because it hasn't been offered as a default option. The staff in the shop may have been hinting that this is possible by updating the firmware but in my experience it cannot be changed by a firmware update.
Thanks,
Simon
Hi janelqz, welcome to the Sony Forums
Have you located the language menu options? Chinese should be able to be selected in the Setup Menu 6 Language options.
If you need any more help just shout
Mick
Thank you Mick!
I checked for several times but still cannot find 'chinese' option. the staff in the shop told me that to ask 'sony support' to get the link and download in the memery card, then update. Is it right? But untill now, I still not recieve.
Hello janelqz
Thanks,
Simon
