I have a NEX-5 and LA-EA1 which works fine for some lenses, but I would like to upgrade to the LA-EA2 adapter, however, rumor has it that it will not work on the NEX-5 before another firmware update, yet I can find no mention of this on any Sony site.
Is this reality? And where can information be found regarding this?
Thanks
Hi robox3000
I belive there is a NEX-5 firmware update due some time this winter which will fix the EA2 compatibility problem.
The page to watch is here on the NEX-5 tech support site.
Mick
Hi robox3000
Mick
