Hi! I can't update my NEX-3 (currently firmware v3).
When I try to run the .exe file that I downloaded from Sony's site (www.sony.fi) I get a message: "filename.exe is not a valid win32 application". I've tried it with two PCs (one Vista/32bit, the other 7/64bit) and I get the same result.
Any help? Thx!
Hi jh_123, welcome to the Sony Forums
This is the v4 NEX-3 firmware upgrade currently on the Sony database, compatible with both of those operating systems:
Hope that works
Mick
Hope that works
Mick
