Hi, I have connected my A550 camera to a Celestron Travel 70 telescope using a T2 Adapter. Successfully taken photos during daylight. When trying to take a picture of the moon at night, all I can see in Live View is a spot of light. I have tried focusing the moon through the telescope but I still get the same. I also get the same when I try connecting the camera through the telescope's diagonal.
This is my first time of trying to use a telescope, so any help would be much appreciated.
Hi Mary,
Can't answer your question I'm afraid, but would suggest having a look at this link on the subject.
http://cs.astronomy.com/asy/astro_imaging/f/16/t/45250.aspx
You could always post the same question there as the author seems very helpful 🙂
Good luck.
Martin
Mark,
Camera was setup as follows:
Mode M
Manual focus set using the switch on the body of the camera
Timer 1/250
Centre weighted metering
AF area set to spot
ISO 400
Aperture Not set as connected to telescope
Hope that helps.
Mary
Hi Mary,
Good luck.
Martin
yep, i'm struggling also, from what i've read it could be a case of your not being able to focus at the distance you need, so it suggests that you may need an extention tube or a barlow lens ?
i hope you can get this sorted
Mark.
