I want to purchase a Sigma 10-20mm f4-5.6 EX DC LensSigma 10-20mm f4-5.6 EX DC Lens for my a200.
Will this fit?
This lens should be OK on your camera with the Sony mount.
If you intend using it on the SLT Translucent Mirror Sony Alphas, check that the lens you buy has been modified as there was a possible aperture operation problem ONLY with the SLT33 and SLT55 models.
