I have bought an L Bracket foldable for my Sony A7IV. When I mount my Hähnel Remote, there is no room for the USB connector on the side of the camera due to the frame being pulled out as far as possible.
Can you get a converter/cable with an angled plug and jack connector to remote, or how to solve the problem.
Per H. Nissen
Solution is found. A company AV-cables.dk can deliver a convertor like this and i expect that this is a solution. Have ordered in an are ariving tomorrov with mail.
Solution not working. These angel adapters has not enough connectors.
Problem not solved. 🤐
Hey @itnisse
My opinion is to use a compatible grip with the camera to be able to guarantee that it will work. Having many 3rst party devices included in the connection might affect the functionality.
This vertical grip for example:https://support.d-imaging.sony.co.jp/www/cscs/accessories/compatibility.php?area=eu&lang=en&mdl=ILCE...
This suggestion is a battery grip, and it is not the same function as the Smallgrip used to turn the A7IV from landscape to portrait on the tripod.
Hey Itnisse, maybe some other user can help you with the adapter, but if you're interested, the below are all the compatible Sony accessories:
A adapter for Smallrig dosn't exists. Hope they could be more serius on website.
Per
Hey Itnisse, you can pass your feedback to Sony too: https://services.sony.co.uk/supportmvc/en/Contact/Email?cat=mobile&tab=Tips
