I have carefully followed SONY instructions to install SONY drive on computer and then after restarting to run 01_Update_ILCE1V135. When I run 01_Update_ILCE1V135 I get the error message to check system security. The security dialogue give no option to accept Sony Imaging Software, just the normal App Store and App Store and Identified Developers.
I beige a new option to allow Sony Imaging products should appear below the App Store and Identified Developers option - but it dies not. Any advice ? Hoping not to upgrade the computer system as this always slows the machine down.
Thanks in anticipation
The reboot of a macintosh is not a common action. But you can try in that case and retry to lunch the updater.
If doesent work I succest to find a windows 10 pc to update the camera. Sony hate mac users, it's not easy to manage his softwares out of windows
Absolutely yes! Thanks for your feedback.
I suggest to read some discussions about what can happen upgrading to 2+ firmware version before to upgrade from 1.35
