Hi Blindasabat101, welcome to the Sony Forums
The only source for Sony parts I know of is the US-based ServicesPLUS https://www.servicesplus.sel.sony.com/sony-parts.aspx
and I'd suggest the best way of finding the part number would be to call them. I did a quick search on there and although I found your flash model, there was nothing that identified the bulb as such.
Are you looking to replace a broken one?
Mick
Mick
