How to use Pentax A Zoom on NEX 5 no pin connection is there a setting to overcome this?
Are you getting a message that the lens is not recognised?
Try this: -
Turn on -> Menu -> Setup -> Release W/O Lens -> Enable
Hi there -I have a Pentax A mount & a sigma zoom and want to connect them to my nex 5. What converter did you use, where from and is it working? Liz
