Hello!
How do I connect my A7R II to my iPad using cables? I want to be able to see what is in the display on my IPad.
Sincerely
Vladimir
You need a mini HDMI connection to be able to.
Here's a page from the manual and here is a troubleshooting page for HDMI connection.
@vladimirlagunas1969, did you manage to do it?
I will try this weekend
I don't think iPads allow the screens to be used as external displays through cables tbh, unless used as an external display on a Mac.
I think it will have to be done wirelessly through imaging edge software.
Or alternatively you can also use a video wireless transmitter like DJI raveneye using the Ronin software.
@Lord_viridis, I have no knowledge about iPads, I wanted to suggest the Imaging Edge app, but vladimirlagunas1969 was specifically asking about a cable connection, the suggestions seemed interesting. I was just waiting if they didn't work to suggest IEM.
